Oppo 93 Gets Stuck On "the American"
8 replies to this topic
#1 Mjr69
Mjr69
  • 1,717 posts
Posted 13 May 2012 - 07:38 PM
This hasn't happened to me before (the Oppo letting me down) and I am reluctant to update firmware just for one disc. I put the disc into my aging Pioneer BR player and no problems at all. George Clooney is getting on in age in HD goodness...
Has anyone had the same problem with this disc - or should I refresh my cache or upgrade the firmware? Anyone?
#2 Quark
Quark
  • 2,641 posts
Posted 13 May 2012 - 09:16 PM
I had no problems playing the US version of The American on my 95 with the Dec 2011 firmware.  Is your disc a local release?
#3 Mjr69
Mjr69
  • 1,717 posts
Posted 13 May 2012 - 11:28 PM
Yes  local release and presume unlocked as I didn't get  the "wrong region" slide. It goes right through to the menu and then stalls
#4 bbar
bbar
  • 6,812 posts
Posted 14 May 2012 - 08:12 AM
Try selecting a chapter.
Also reset BD memory
#5 blairy
blairy
  • 1,821 posts
Posted 15 May 2012 - 09:15 AM
Clear the BD live memory.
If you've got BD live turned on, turn it off (or vice versa).
Let us know how you go.
chers
blairy
#6 blybo
blybo
  • 1,334 posts
Posted 15 May 2012 - 09:38 AM
I played a rental BD on my 93 without issues late last year.
#7 jsmith
jsmith
  • 4,306 posts
Posted 15 May 2012 - 01:05 PM
... depending on the American in question, this may not be a bad thing at all. ;)
JSmith :ninja:
#8 Mjr69
Mjr69
  • 1,717 posts
Posted 15 May 2012 - 09:59 PM
I have spent more time now with this - I had BD-Live on, switched it off, deleted my memory which was only 1MB out of 956MB available, tried using the next/up chapter button, tried jumping ahead to the top menu whilst loading. It is the local version and listed as ALL Region. I am over it..... the movie was OK but not brilliant anyway... Thanks for the suggestions, cheers, MIke
#9 blybo
blybo
  • 1,334 posts
Posted 15 May 2012 - 10:55 PM
I actually thought it was a brilliant movie... but each to their own. Maybe just a bad disc/player match, as I said I had no issue with a rental copy late last year with what was then current firmware. Is this title known to have issues that firmware fixes?
