Help With Distribution
18 replies to this topic
#1 BassTeQ
BassTeQ
  • 25 posts
Posted 04 May 2012 - 11:47 AM
Hi, I've currently got 4 outlets running off a splitter in the roof, ATV/DTV picture quality is pretty good.
I'd like to upgrade this to cater for 6 outlets with the ability to have 2 inputs, 1 for the antenna, and 1 for a RF modulator -> UHF. What equipment would be required?
The RF modulator I currently have is being feed back into the antenna loop at one of the outlets via a splitter, the picture quality on the TV's at the other end of our house is very grainy. I’m hoping by having a dedicated line from this modulator back into a distribution system will improve the picture quality.
Appreciate any assistance.
Thank you
#2 nbound
nbound
  • 778 posts
Posted 04 May 2012 - 01:19 PM
A combiner/diplexer between the aerial/masthead and splitter will allow the modulation to be mixed in with less insertion loss (and negating the need to be attenuated by 2 splitters in reverse before splitting).
Assuming the signal levels are reasonable it may be possible to just replace the 4way splitter with a 6way splitter with no issues, if amplification is required, you'll still need the 6 way split, so no cash lost (a splitter is bugger all $$$ anyway).
Edited by nbound, 04 May 2012 - 01:21 PM.
#3 BassTeQ
BassTeQ
  • 25 posts
Posted 07 May 2012 - 09:11 AM
Thanks for the reply! Any particular brands/models you could recommend?
I was considering the following:
Diplexer
http://www.radiopart...LEXER - KINGRAY
8 way splitter
http://www.radiopart...TER OR COMBINER
Edited by BassTeQ, 07 May 2012 - 09:18 AM.
#4 The Baja
The Baja
  • 277 posts
Posted 07 May 2012 - 10:50 AM
Diplexer
http://www.radiopart...LEXER+-+KINGRAY
8 way splitter
http://www.radiopart...TER+OR+COMBINER
Those Parts look awfully Expensive to me
Cheer's
The Baja
#5 debruis
debruis
  • 399 posts
Posted 07 May 2012 - 03:51 PM
I would not use the diplexer shown on the link as it is not f-type. Its equivalent in f-type will be fine. Splitter is OK.
#6 BassTeQ
BassTeQ
  • 25 posts
Posted 07 May 2012 - 04:31 PM
Thanks, I'll be sure to stick with the F-type.
Baja, I havent hunted around for the best price, just looking to select the right products.
#7 M'bozo
  • 2,685 posts
Posted 07 May 2012 - 05:18 PM
So, what transmitter are you utilising for your signals? Failing that, what suburb/city/state are you in?
Make & model would be helpful.
As much information as possible is helpful. Even a rough diagram of your current setup could be helpful.
#8 BassTeQ
BassTeQ
  • 25 posts
Posted 08 May 2012 - 09:13 AM
Hi M'Bozo,
Im not sure of the splitter currently in the roof, but it looks like a cheap one, non F-type. Im on the west side of Melb.
The RF Modulator is the one from DSE http://dicksmith.com...video-modulator
I currently have the output of this going into a kingray booster, then into a splitter, then into a wall plate. This isn't ideal which is why Id like to find a better solution.
#9 M'bozo
  • 2,685 posts
Posted 08 May 2012 - 06:34 PM
OK, I've used that particular modulator before.
My preferred approach: I feed FTA signals into the modulator at roughly the same level as the RF output of the modulator in standalone mode.
The RF modulator frequency is set so there is no interference to or from other signals present in the mix.
The output of the RF modulator is then amplified to a suitable level, to split & distribute around the house.
Without a level meter of some kind this approach may not be suitable for you.
Additionally, all FTA signals here are on UHF, making it easier for me.
#10 nbound
nbound
  • 778 posts
Posted 08 May 2012 - 07:23 PM
Indeed, if it has RF passthrough, then just plug it between the aerial and your spliter (unless you have a masthead amp or anything else requiring power towards the aerial - as it wont pass power). Might need to get a sparky in to install a GPO up in the roof though - in which case you could then put your masthead power supply (if applicable) before the input.
Edited by nbound, 08 May 2012 - 07:23 PM.
#11 clipper
clipper
  • 368 posts
Posted 09 May 2012 - 09:36 AM
What are you trying to (re)modulate? Pay TV boxes generally have inbuilt modulators.
#12 BassTeQ
BassTeQ
  • 25 posts
Posted 09 May 2012 - 10:56 AM
Im feeding IQ2 into the modulator, there is no RF out on these boxes unfortunatley.
To thow another question into the mix, Im going to upgrade all the cabling to quad RG6, at the wall plates what connection is best to use these days? F-type, or PAL. I currently have PAL circular type plugs but happy to change to F-Type if these are better?
Edited by BassTeQ, 09 May 2012 - 11:18 AM.
#13 nbound
nbound
  • 778 posts
Posted 09 May 2012 - 12:50 PM
Theoretically f-type is better, but pal will be fine to use. PAL plugs cause an impedance mismatch (50ohm vs. 75ohm), but its not going to cause a problem (as 99% of australians will show you). Most modern wall plates whether F or pal are actually F on the back (cavity) side, so get some extra f crimps even if u do choose pal.
#14 BassTeQ
BassTeQ
  • 25 posts
Posted 09 May 2012 - 04:54 PM
Thanks nbound!
#15 M'bozo
  • 2,685 posts
Posted 09 May 2012 - 08:36 PM
Neither does myStar HD, doing an RF distro for one next week.
PQs not to bad on small screens,either.
#16 The Baja
The Baja
  • 277 posts
Posted 11 May 2012 - 05:53 PM
IQ works Flawlessly when you put it Thru a HDMI input Modulator ;)
Cheer's
The Baja
#17 nbound
nbound
  • 778 posts
Posted 11 May 2012 - 07:45 PM
Haha Baja, well as long as the tv is MPEG4 compatible ;)
#18 BassTeQ
BassTeQ
  • 25 posts
Posted 14 May 2012 - 09:43 AM
Do you have a link to the one you used?
I'm looking at the items below, 2 questions
1. Can the 2 way splitter be used in reverse, as a combiner?
2. Is there much difference between the roll of RG6 Quad I've selected compared to say Belden brand RG6?
Digitek 2-Way F-Type TV Antenna Aerial Splitter 5-2400MHz 10DCS202
http://www.selbyacou...c=0&i=273434745
Digitek 8-Way F-Type TV Antenna Aerial Splitter 5-2400MHz 10DCS208
http://www.selbyacou...c=0&i=273437618
100m RG6 Quad Shielded TV Antenna Coaxial Cable on Roll/Spool CCRG6Q100
http://www.selbyacou...c=0&i=274358348
Thanks!
#19 andrewlace
andrewlace
  • 200 posts
Posted 19 June 2012 - 07:53 PM
Don't use a two way splitter to mix off air signals. You should always use either a diplexer or drop tap to ensure good levels of isolation. I'd go for a 6-10 db drop tap or an m14/5 (band 1-4, band 5 diplexer) from laceys.tv or other supplier.
Recommend staying away from a VHF/UHF diplexer as you'll loose all SBS and 31 on most systems.
A drop tap is non channel specific and will allow for infinite adjustment of channel selection (in many cases this is very helpful). Be sure not to go above channel 52 as the government is set to sell these channels off possibly to the highest bidder (e.g. for cellular communication).
