Igloo Pay Tv Uses Dvb-T2/mpeg-4 Standards
7 replies to this topic
#1 alanh
  • 12,289 posts
Posted 03 May 2012 - 10:16 PM
"New Zealand's national broadcast transmission company Kordia has built the country's first DVB-T2 transmission network for IGLOO TV. The new pay television service is set to launch in the first half of 2012 and will be the first in the Asia-Pacific region using DVB-T2.
Kordia owns and operates New Zealand's third largest telecommunications network by geographical reach and provides terrestrial transmission services for all the major television operators. The new DVB-T2 service will be delivered from 19 main sites and will be deploying a single physical layer pipe (PLP). It has chosen modulation parameters that will provide comparable coverage to their existing DVB-T services. However, the new technology has raised the data rate achievable in an 8 MHz channel from 26 Mb/s to 38 Mb/s allowing IGLOO TV to operate 12 SD services in a single former analog TV channel. The DVB-T2 MI signal is distributed over its nationwide IP network as a multicast IP stream, feeding the transmitters directly with an IP stream, thereby simplifying the number of devices in the distribution network." DVB.org
#2 bassett
bassett
  • 750 posts
Posted 04 May 2012 - 04:27 PM
It's just another Internet streaming service   http://www.igloo.co.nz/pages/home.php  Good luck with NZ internet speeds.
Also no sign of pricing, except there advocating a 30 day contract  [month by month presumably ]
I can't see SKY NZ  allowing it to get  that big,  If it servives
#3 nbound
nbound
  • 778 posts
Posted 04 May 2012 - 05:19 PM
Its DVB + streaming. Will be interesting to see how it goes. Good selection of stations, though some will be a little annoyed with the lack of sports channel (though they still have 1 more SD channel spot to fill atm)*
Edit:
* has a PPV sports channel
Edited by nbound, 05 May 2012 - 03:56 PM.
#4 alanh
  • 12,289 posts
Posted 04 May 2012 - 05:34 PM
DVB-T2 is a terrestrial broadcast system, it has nothing to do with the internet. As the quote says they are installing 19 transmitters.
#5 bassett
bassett
  • 750 posts
Posted 05 May 2012 - 03:09 PM
Just how "Thick" are you AlanH  Try reading there web page, before you respond,  I assume you  have
mastered the art of reading, or do you simply look at the pictures..
IGLOO is pretty fancy. it has the ability to stream loads of blockbuster movies and TV episodes
over the I N T E R N E T  You simply rent what you're after from your couch and IGLOO will sort out the rest.
i
Edited by bassett, 05 May 2012 - 03:14 PM.
#6 nbound
nbound
  • 778 posts
Posted 05 May 2012 - 03:31 PM
Actually bassett, AlanH is correct insofar as Igloo is to be transmitted terrestrially. The quote you have posted refers to PPV and streaming content though.
Edited by nbound, 05 May 2012 - 03:51 PM.
#7 Malich
Malich
  • 501 posts
Posted 05 May 2012 - 03:44 PM
(edit: The first part of this is a reply to basset; nbound also jumped in and corrected him before I finished writing this)
No, this time he's right - IGLOO is currently an internet streaming service; Kordia have built / provided a DVB-T2 broadcast network for them. Expected launch is mid-year.
Put simply, IGLOO is starting up a PPV service over DTV. Apparently they're using some form of conditional access / access control, but I can't be arsed looking up the details.
Alan, all this could have been avoided if you'd linked the source for your quote. I realise you 'credited' DVB.org at the end of your quote - and I too have been guilty of that in another thread where I mentioned DVB.org as a source when presenting a summary from several - but the straight, up and down, unadorned fact of the matter is that your posts are generally a waste of time and space without some sort of supporting link.
And if you're going to quote a whole press release please, at the very least, link the damned thing. I know you can manage that, because you've done it in multiple other threads you've started over the last few days. You may have obtained the press release you've quoted through some mysterious source that we don't have access to and you are unable to reveal - but it's also readily available on the 'net, and has been for the last week.
(I look forward to the soon-to-be-released by alanh announcement that Haiti is launching DVB-T2. My source? That same link...)
Edited by Malich, 05 May 2012 - 03:57 PM.
#8 nbound
nbound
  • 778 posts
Posted 05 May 2012 - 03:48 PM
Also: http://en.wikipedia....8New_Zealand%29
According to wikipedia, its a 30-day prepaid service, but will have extra PPV and streaming material. (See promo video on main igloo webpage, or citation 5 on linked page - also mentioned specifically a PPV sports channel)
Edited by nbound, 05 May 2012 - 03:54 PM.
