Foxtel Iqhd Planner
9 replies to this topic
#1 parraeel
parraeel
  • 12 posts
Posted 28 April 2012 - 12:06 PM
My Foxtel iqHD multi-room has only one program to be recorded, but it is showing only 59% space remaining in the planner.
Am I missing something?
#2 Aussiedude
Aussiedude
  • 183 posts
Posted 28 April 2012 - 03:10 PM
how many have you recorded? and do you have rewind enabled?
would help if you had some pics. my IQ2 sometimes has about 8-10% extra used that is hidden, when my box goes under 10% it comes back. some glitch ive had for the last month or so.
#3 parraeel
parraeel
  • 12 posts
Posted 28 April 2012 - 03:56 PM
The planner is empty except for the program that is to be recorded..
Rewind is disabled.
#4 miata
miata
  • 1,560 posts
Posted 28 April 2012 - 04:05 PM
Rewind is disabled.
I would be inclined to call Foxtel, have them format the drive and force a firmware update.
#5 Aussiedude
Aussiedude
  • 183 posts
Posted 28 April 2012 - 05:57 PM
try a hard reset?
#6 parraeel
parraeel
  • 12 posts
Posted 28 April 2012 - 06:29 PM
View PostAussiedude, on 28 April 2012 - 05:57 PM, said:
try a hard reset?
I unplugged it from the power point for 10 minutes and then restarted the box, same result.
Will probably give Foxtel a call,athough it is only a second box and don't use it much for recording, it should have more than 59% free.
#7 miata
miata
  • 1,560 posts
Posted 28 April 2012 - 07:22 PM
I repeat, call FOXTEL, have them format the hard drive and force a firmware upgrade.
#8 JB Melb
JB Melb
  • 63 posts
Posted 28 April 2012 - 09:34 PM
Try this.
Press active button and then select setup. Go into Advanced Settings.
You should only have 5 options. Enter 0611 on the remote then press select which will take you into a hidden menu. Select option 4 Full System Reset. That will format the hard drive and delete everything including scheduled recordings.
I've had similar problems in the past and this is where they guided me to.
Edited by JB Melb, 28 April 2012 - 09:36 PM.
#9 parraeel
parraeel
  • 12 posts
Posted 29 April 2012 - 11:10 AM
Thanks JB, that worked a treat.
Will keep this "cheat sheet" for further reference.
Edited by parraeel, 29 April 2012 - 08:06 PM.
#10 JB Melb
JB Melb
  • 63 posts
Posted 29 April 2012 - 09:28 PM
Not a problem, glad it worked.
