Win Channel 84
48 replies to this topic
#1 newtaste
newtaste
  • 240 posts
Posted 26 April 2012 - 09:50 PM
A new WIN channel appeared in Wollongong today. Channel 84. Name is TBA, is in MPEG 2, just showing a loop for now.
Edited by newtaste, 26 April 2012 - 09:57 PM.
#2 nbound
nbound
  • 778 posts
Posted 26 April 2012 - 10:57 PM
Its probably just going to be eXtra (9's go at TV4 - already available in metro/nbn areas)
#3 BamBBBam
BamBBBam
  • 1,005 posts
Posted 27 April 2012 - 09:17 AM
Only Nine O&O stations (Syd,Mel,Bris and Newy)
#4 hrh
hrh
  • 187 posts
Posted 27 April 2012 - 09:21 AM
Being advertised on STW as coming - 94
#5 BamBBBam
BamBBBam
  • 1,005 posts
Posted 27 April 2012 - 09:42 AM
Yep - I was just trying to clarify the above poster saying that it was available in "metro areas"
#6 DrP
Posted 27 April 2012 - 11:41 AM
WIN has had about 1.5Mbit/sec of nulls in its transmission in Mackay QLD in the past.  Compared to any of the others this is quite large - SBS is less than 100kbit/sec of nulls, while the 2nd worst (assuming WIN is the worst) is about 300kbit/sec.  Should this additional waste of space come to Mackay, I wonder if WIN will task that 1.5Mbit/sec of wasted space to the exercise.
Hmm.  A quick look shows that there is now ~2.8Mbit/sec of nulls.
Not only is early morning TV splattered with infomercials and other outright ads, there is now two 24 x 7 channels packed with the crap.  Whilst I can believe there is sufficient money coming in to support one such channel, two of them?  It boggles the mind somewhat.
Edited by DrP, 27 April 2012 - 11:45 AM.
#7 cageswood
cageswood
  • 160 posts
Posted 27 April 2012 - 03:11 PM
Here in Ballarat,if it's another infomercial channel i'll delete it
#8 BamBBBam
BamBBBam
  • 1,005 posts
Posted 27 April 2012 - 04:46 PM
Can't find anything new on scan in Perth. could we be lucky and avoid this detritus?
#9 nbound
nbound
  • 778 posts
Posted 27 April 2012 - 04:58 PM
Perth 9 (owned by WIN) is callsign STW, a poster above has said theyve got it from Perth 9. Try 94 instead of 84 if you havent already. Being advertised on 9 Perth at this stage. But no channel as yet.
Edited by nbound, 27 April 2012 - 07:46 PM.
#10 Amraks
Amraks
  • 10 posts
Posted 27 April 2012 - 06:40 PM
tassie has it just a loop like they used to do with there other new channels.
channel 84 TBA its called here.
Edited by Amraks, 27 April 2012 - 06:44 PM.
#11 hidefdave
hidefdave
  • 272 posts
Posted 27 April 2012 - 06:45 PM
It's on here in Western Vic. Channel 84. Just shows up as "TBA" :unsure:
D.
#12 miagi
miagi
  • 293 posts
Posted 27 April 2012 - 07:06 PM
Confirmed as 84 here in Tassie..Hobart.
Looks very low bitrate.
#13 hrh
hrh
  • 187 posts
Posted 27 April 2012 - 07:24 PM
No, only being advertised as coming - not here yet.
#14 nbound
nbound
  • 778 posts
Posted 27 April 2012 - 07:45 PM
Ah fair enough, Ill edit to reflect this :)
#15 GoForMoe
GoForMoe
  • 1,276 posts
Posted 27 April 2012 - 08:15 PM
Wait until Southern Cross jump on the bandwagon, Ten's in a financial hole so it is no doubt coming.
Nine Melbourne have gone from about 300k of nulls to over 1Mbps of nulls since adding Extra. At the moment with the football on the allocations are a bit better than usual, but Gem is on 10Mbps, Nine on 4.8, Go! on 2.8 and Extra on 2. Though usually Gem is nearer 8Mbps, Nine a bit higher and occasionally Extra peaks above Go.
WIN don't have datacast licences yet, which certainly explains the lack of full service, but in my reading of the multichannel rules that makes WIN's test channel illegal (as there's no exemption under the channel limits that allows it). If you have a bit of time, there's nothing to lose making a complaint to ACMA about the potential technical breach (though there's always the chance ACMA are just late in updating their site).
I honestly don't mind Prime/Seven's channel (by comparison), there's a reasonable amount of community shows on there, a lot of stuff previously only on Channel 31 has found its way onto 4ME. And as a whole it has far less pure infomercial programming. Extra on the other hand is wall to wall paid advertisements followed by 7 hours of 'chat' television, the worst of the worst. I do hope for the sake of regional viewers WIN is at least doing its own ad channel rather than carrying Extra as is, or that the inclusion of WIN would improve the quality of the content on it. Considering these channels now seem inevitable from all the broadcasters, at least get them right.
#16 DrP
Posted 28 April 2012 - 09:30 AM
The MPEG-2 demo loop is now running here too.  A quick look with tsreader shows WIN is still running about 1.5Mbit/sec of nulls.  I wonder why WIN has to maintain such a high rate of nulls compared to all the other networks.  Given that WIN and ABC share a playout centre and, presumably, therefore have access to the same standard of equipment, WIN should be able to achieve rates similar to ABC's 500 kbit/sec of nulls.  1 Mbit/sec may not seem like much but if it was given to WIN SD and/or GO! it would make a considerable difference to them.
WIN ~1.5 Mbit
ABC ~0.5 Mbit
7 QLD ~0.8 Mbit
SBS ~0.15 Mbit
SCA ~0.5 Mbit
Edited by DrP, 28 April 2012 - 09:33 AM.
#17 moregeld
moregeld
  • 24 posts
Posted 28 April 2012 - 09:00 PM
perhaps its Win's 3D channel for the olympics??  I know Channel 9 is having it.
#18 nbound
nbound
  • 778 posts
Posted 28 April 2012 - 09:26 PM
Not enough space in the existing multiplex (9 is getting special permission under trial provisions to operate a special transmitter).
#19 McDigital
McDigital
  • 1,400 posts
Posted 29 April 2012 - 08:34 PM
G'day,
I've been getting correspondance from people in Regional Victoria, that WIN has a channel 84 appearing as TBA
We all know it'll be "Extra" with more informercials
But, tonight, a random idea while this was in discussion, Channel Ten are probably next to release a channel, instead of a datacasting channel, how about something interesting, what ever happened to that idea of a music channel on Free to Air..... Nudge, Network Ten!
Ahh...was worth a try
Edited by McDigital, 29 April 2012 - 08:35 PM.
#20 nbound
nbound
  • 778 posts
Posted 29 April 2012 - 08:49 PM
Not until they are allowed to carry more than 2 multichannels. Datacasting is a loophole.
#21 Port Adelaide Fan
Port Adelaide Fan
  • 88 posts
Posted 30 April 2012 - 09:57 AM
I am in Adelaide and got ch 94 win gold today.
#22 hrh
hrh
  • 187 posts
Posted 30 April 2012 - 01:07 PM
Yes, STW Perth now has the same. Just a static slide with music. Starts 1st May it says..
#23 Amraks
Amraks
  • 10 posts
Posted 30 April 2012 - 04:38 PM
starts tommorow tryng to update my program guide on mythtv
#24 nbound
nbound
  • 778 posts
Posted 30 April 2012 - 04:57 PM
So rebadged eXtra? Or anyone heard anything else...
#25 Amraks
Amraks
  • 10 posts
Posted 30 April 2012 - 06:22 PM
no luck with shepherd tv guide. shepherd has not even heard about it.
I think its a rebadged extra channel.
Im going to program it to start recording tommorow at between 5 am to 8 am just to see what it started off like.
Bet you its just info commericals that I will just be deleting.
Desprate pricks if its info commericals, what happened to running them thru the night.
