Cables For Speakers[Again!]
157 replies to this topic
#1 blacklikesunday
blacklikesunday
  • 691 posts
Posted 22 April 2012 - 09:13 PM
i imagine there has been a debate about speaker cables for years? the wiring i have is really cheap so i want to change it, if that is necessary of course. mine have a few connections along the cable as well, which i heard isn't the ideal situation.
i read a couple of articles on the 'net where one said 'yes' you will notice a difference with better cables, while the other predictably said the opposite.
so do more people say better cables/better sound?
i read that i should get 16 gauge cables?  so would this particular wiring be ok do you think?
http://www.selbyacou...104&i=246734282
thanks.
#2 :)
  • 30,946 posts
Posted 22 April 2012 - 10:39 PM
if just looking for some good budget stuff thats well made the australian made tycabb linear crystal is a great buy.
http://www.tycab.com...ar-crystal.html
as to anything else making a difference. answer is simple. check with most specialist stores most have cable sets they use. ask if can borrow a set over a weekend or overnight. try for yourself. if find its worth gettting get em. otherwise dont bother :)
#3 nbound
nbound
  • 778 posts
Posted 22 April 2012 - 10:55 PM
Short Answer: No, within reason, there is very little difference.
Some of the stuff is absolute wank - Ive seen on a certain popular brand speaker cable markings that say "Signal Flow >>>>>" down one side of the cable.... (Audio is AC).
#4 Cafad
Cafad
  • 49 posts
Posted 23 April 2012 - 08:16 AM
Speaker wire is either thick enough or not thick enough.  Even the OFC numbers don't mean as much as many people claim.  If you have spent megabucks on your gear then maybe you need to worry about dielectric effects or silver cables vs copper vs cryo treated vs blessed-by-virgins-and-rolled-on-the-back-of-a-holy-goat-in-the-first-rays-of-sunlight-of-the-dawn-of-the-winter-solstice brand cable (patent pending) but for most of us it is just nice thick copper that does the trick.
#5 ajm
ajm
  • 10,308 posts
Posted 23 April 2012 - 08:46 AM
Cable made from recycled cans (of worms) seems to be popular.
#6 Digital Penetration
Digital Penetration
  • 423 posts
Posted 23 April 2012 - 09:02 AM
Why has this blown up here and over on Whingepool at the same time (again...)? Isn't the magic fairy dust speaker cable selling fast enough at the moment?
#7 :)
  • 30,946 posts
Posted 23 April 2012 - 09:22 AM
its just the usual hoopla that surrounds any mention of 'cables' in a discussion that seems to drive people in a frenzy :lol:
#8 Chicken Man
Chicken Man
  • 5,786 posts
Posted 23 April 2012 - 10:03 AM
Here is a selection guide for speaker cable, at these very low impedances that loudspeakers work at no other electrical characteristc matters other than the series resistance of the conductors themselves.
You will see from the chart that very long speaker cable runs are possible for any given loss in DB for a stated speaker impedance.
Just select the wire diameter and the speaker impedance and you have the maximum length for any acceptable loss in power.
There is nothing more to it than that. :twitch:
There is also a  .PDF available of the chart, just google 'Speaker Cable Selection Guide'
http://www.beldeneme...speaker-cables/
C.M
#9 gone_bush
gone_bush
  • 5,589 posts
Posted 23 April 2012 - 02:47 PM
If you want to spend, say, around $10k on speaker cables, give me a PM. Have I got a deal for you!!! :winky:
#10 ajm
ajm
  • 10,308 posts
Posted 24 April 2012 - 08:38 AM
If you can up the budget to $50,000 I have just the thing.
#11 gone_bush
gone_bush
  • 5,589 posts
Posted 24 April 2012 - 09:32 AM
That's just what this industry doesn't need - another rip-off merchant! :lol:
#12 ajm
ajm
  • 10,308 posts
Posted 24 April 2012 - 10:08 AM
But there are so many suckers out there. Surely there's room for one more retailer ready to cater to this segment.
#13 myrantz
myrantz
  • 14,939 posts
Posted 24 April 2012 - 10:11 AM
meh... different speaker cables introduce different flavours. as such use cables to tune the system.
because its about tuning, what is best for me may not be best for you.. hence the mass debate.
for long runs (say > 3m) i'd go budget. have  look at online webshops and take your pick. if you need to terminate with plugs or spade, see if you can find non brass ones. i got some fantastic spades from hk but alas they don't make em anymore. :(
#14 Chicken Man
Chicken Man
  • 5,786 posts
Posted 24 April 2012 - 01:34 PM
What's a catalyst, Mum ?
C.M
#15 gone_bush
gone_bush
  • 5,589 posts
Posted 24 April 2012 - 03:40 PM
:hyper: :hyper: :hyper: :hyper:
#16 Drizt
Drizt
  • 5,885 posts
Posted 24 April 2012 - 06:47 PM
Someone has drunk the kool-ade :)
#17 Chicken Man
Chicken Man
  • 5,786 posts
Posted 24 April 2012 - 07:44 PM
Yes, blind obedience to untested beliefs can have unfortunate outcomes, as history has shown.
We are only talking about cables here but a noose is always possible. :unsure:
C.M
#18 gone_bush
gone_bush
  • 5,589 posts
Posted 24 April 2012 - 08:08 PM
"Only talking about cables"!!! :wacko:
Heresy!!! Off with his head. :lol:
#19 yorac
yorac
  • 22,620 posts
Posted 24 April 2012 - 08:09 PM
I continue to be amazed that nobody heads into their local Harvey Norman for advice on these matters............
and a great deal as well...............
#20 BladeRnR
BladeRnR
  • 3,519 posts
Posted 24 April 2012 - 08:48 PM
Or head for their closet to grab a couple of coat hangers :huh:
Blade
#21 yorac
yorac
  • 22,620 posts
Posted 24 April 2012 - 08:49 PM
Blade
Certainly great for HD TV....................
#22 BladeRnR
BladeRnR
  • 3,519 posts
Posted 24 April 2012 - 08:55 PM
because its about tuning, what is best for me may not be best for you.. hence the mass debate delusion.
That's odd - I always thought it was about Current Flowing through a Transition Metal ;)
Make mine a trio of Gelato - Chocolate, Lemon and Pistachio please
Blade
Edited by BladeRnR, 24 April 2012 - 08:57 PM.
#23 BladeRnR
BladeRnR
  • 3,519 posts
Posted 24 April 2012 - 08:56 PM
Remember when I was a kid and Dad introduced me to that infallible piece of flexible technology. Best damn antenna I've ever seen..
Blade
#24 myrantz
myrantz
  • 14,939 posts
Posted 25 April 2012 - 01:21 AM
heh heh... i got some new snake oil up my sleeve.. :P wait till u hear the claims.. :ninja: i'd post them later. :hyper:
for some reason i thought this was about ht. juz realised its wrt 2channel. in that case one should be able to hear differences. ymmv, but i like ribbonteks. approx $500-600 but considering the quotes from this thread this is pocket change. or save even more by diy your own flat cable.
#25 gone_bush
gone_bush
  • 5,589 posts
Posted 26 April 2012 - 09:13 PM
Obviously you've got more money than sense. JB are having a 10% off sale. :winky:
