Hi there,
I am about to upgrade to MyStar HD and want to know if I can save programs recorded to my current MyStar box by copying them over to an HDD or by any other means?
Matt
Copy Austar Shows To Hdd?
brissyboy
, Apr 17 2012 06:13 PM
2 replies to this topic
Posted 17 April 2012 - 06:13 PM
Posted 17 April 2012 - 07:45 PM
You won't be able to copy the "files" off. However you can probably attach the box to a DVDR (instead of out to a TV). SO you press play on the Mystar and the REC on the DVDR and "copy" files. Not ideal but doable.
If you don't have a DVDR then you van possibly buy a PC converter cable instead. Something like this
Posted 18 April 2012 - 04:53 AM
Mystars have macrovision signalling enabled when playing back recordings. Many DVD / HDD recorders take notice of it and may refuse to record. Some recorders have hidden macrovision disable options (press buttons in certain order, hidden menu options etc) but a 'video stabiliser' will also defeat it. PC recording devices can also take notice of macrovision but many don't or react badly to it (crash).
