Iqhd Box: Hd Options In Advanced Settings
ambrose22
, Apr 12 2012 02:17 PM
7 replies to this topic
Posted 12 April 2012 - 02:17 PM
I was looking thru the settings in my new IQHD box and noticed that you can set hd as 720, 1080, pass through or auto. It was set at 720 when I got it. Has anyone worked out which setting will give the best results overall?
Posted 12 April 2012 - 03:41 PM
Depends on what you watch and what you watch it on.
Most of foxtel HD is broadcast at 1080i. The exception is ESPN, broadcast at 720p.
Now if your TV has a native resolution of 1080i or 720p then that it is probably the best to use.
However most recent model TV's are 1080p. So you need to try this on your TV. Does it do a better job of converting (or whatever the technical term is) 1080i to 1080p or 720p to 1080i?
Let your eyes be the judge.
blairy
blairy
Edited by blairy, 12 April 2012 - 04:13 PM.
Posted 13 April 2012 - 11:45 AM
TV is Pioneer 508xda, 1365x768. Even tho the Kuro upscales well, with box on 1080 it seems a bit juddery, so I'll try 720 and auto. Thanks, Blairy.
I wonder what the difference is between pass through and auto.
Posted 13 April 2012 - 11:49 AM
'Auto' it detects your TV and outputs everything at that resolution, for yours this would probably be 720p?
'Pass through' it outputs everything at its native resolution eg ESPN channels at 720p, other HD channels at 1080i, SD channels at 576i
Posted 13 April 2012 - 12:01 PM
I have same tv,theres a setting in it that if its not on the right one things like football are jittery.Will check after and let you know what it should be on ,that might be more your problem as i really see no difference in either 720 or 1080.
Edited by wheelz, 13 April 2012 - 12:01 PM.
Posted 13 April 2012 - 01:38 PM
Ok ambrose had a look, make sure drive mode on the pioneer is set to 2 otherwise footysports will be jittery.
menu->options->drive mode.
Posted 13 April 2012 - 05:59 PM
That makes some difference. Thanks.
Posted 13 April 2012 - 11:54 PM
Have tried those settings, but still can't read the very bottom text on CNN, though I'm not sure if it's the stream rather than my TV.
