Noise Cancelling Headphones - Recommendations?
5 replies to this topic
#1 dave_con
dave_con
  • 731 posts
Posted 12 April 2012 - 09:45 AM
Hey there,
can anyone recommend a pair of noise cancelling headphones that they are happy with?  I'd like to get some to use with my iPad on flights so that I don't have to turn the volume up to maximum to hear the audio.  I only fly a few times a year, so I probably don't need the super-expensive type, but am happy to hear any suggestions from anyone who has these (and whether you like them).
#2 Grahameh
Grahameh
  • 57 posts
Posted 13 April 2012 - 04:02 PM
Have a look at Headphonics, you will get some good recommendations there. http://headphones.com.au/
#3 dave_con
dave_con
  • 731 posts
Posted 13 April 2012 - 04:03 PM
Thanks!
#4 Andyaussie013
Andyaussie013
  • 6 posts
Posted 19 May 2012 - 09:41 PM
Well first off, never buy headphones  you haven't heard in person. Head on out to a  music store and listen (bring some music of yours to play on them). I would Like to recommend to Check reviews of Bose Noise cancelling headphones on Audio Solutions .
Edited by Andyaussie013, 19 May 2012 - 10:27 PM.
#5 ccs
ccs
  • 297 posts
Posted 29 May 2012 - 04:51 PM
Ideally, yes, and definitely for better headphones in a normal situation. However, in an airplane, with noise canceling on, and wailing kids, noise canceling capability and comfort is just as important as sound quality.  There is no other way to asses it other try it on the longer flights.
I own a number of headphones, low and high end, both normal and noise canceling, and have tried most of them on the planes.  I still own a Plane Quiet headphone, bought directly from USA.  While they do not rate as well as Bose, my concern was losing or damaging the headphones. It is very easy to leave it behind on the plane, accidentally sit or pull on it etc, especially if you fly often.  A $100 lost or damaged headphone is easier to live with than a $400 one!  You could argue that you will take more care with the more expensive item, but one can do stupid things when tired on a long flight.
Another good site to look at: http://www.seatguru....ing_review.php.
#6 blacksnow17
blacksnow17
  • 6 posts
Posted 20 May 2013 - 06:46 PM
would a closed ear model like a Senn HD 201 or HD 202 count as noise cancelling? they're a good bang for your buck.Cheap,more than decent quality and you can't really hear any ambient noise once you put them on
