Hi everyone
I'm having audio problems with my DVD/VCR combo. The audio keeps crackling up which is obviously annoying. I use the standard red and white cables to hook up my player up to the TV and I have had the combo for about 4 or 5 years. I have had no problem with it up to now. The video is fine, nothing wrong with that, its just the audio that keeps crackling up. I have tried tightening up the red and while cables at the back to make sure they weren't loose or anything, but that didnt work. Would a new set of red and white hook up cables fix my audio issue? Help would be useful, thanks
Note: This issue applys just for the DVD drive
Dvd Audio Issues
sharp_1
, Apr 04 2012 03:10 PM
3 replies to this topic
Posted 04 April 2012 - 03:10 PM
Posted 04 April 2012 - 05:08 PM
Magnum72,I don't have a internal tuner plugged into the TV as I only use it for DVD/VHS playback. However I just tested it again with a couple of different DVDs, and I didn't get any cranking audio at all with the first disc I inserted, I did get a little bit of audio cranking with the second disc although no wear near as much as before. I should mention that it DOESN"T HAPPEN ALL THE TIME. Sometimes it actually plays fine, but at other times it doesn't and its annoying - it is very inconsistent in other words. VHS playback is 100% fine, and as for the model it is a Samsung DVDV6700 - http://static.bhphot...x345/485716.jpg
Cables I use - http://www.djtechtoo...a-cable-300.jpg
Edited by sharp_1, 04 April 2012 - 05:09 PM.
Posted 07 April 2012 - 02:58 PM
Magnum72, on 05 April 2012 - 10:48 AM, said:
Ok, before deciding if a repair is necessary at this time your combo has 2 audio outs, 1 is on the left where you have yellow, red, white in and out-I'm guessing you are currently connected to your TV from this output.
Try changing to the audio out that is too the right near the component(red, green, blue connections) and S-video.....It might fix your problem-might be temporary on no fix at all....I suspect you have a fault with the audio out from the dvd side of things probably not worth fixing.
yellow for composite VCR output to say AV1 input on the TV, and red, blue and green component video from the DVD side together with the corresponding red and white additional audio leads all into a COMPONENT set of inputs on the tv and then
switch the input source on the tv from AV1 for watching VCR tapes to the correct COMPONENT input to watch DVDs.
Good luck, as has been said probably not worth repairing when compared to a new one with warranty if you can't get it going
yourself.Tazzy.
Posted 07 April 2012 - 07:51 PM
As suggested if the other l/r rca doesnt work try a digital converter like this maybe..it has a loopthrough to simplfy switching if you want to send lossy 5.1 to an avr as well..
http://www.selbyacou...c=0&i=251069032
