Audyssey Multieq Pro Kit ?
DinoG
, Mar 30 2012 01:06 PM
9 replies to this topic
Posted 30 March 2012 - 01:06 PM
New to DTV.......
Where can I buy the Audyssey Multi EQ Pro Kit ?
Anyone selling in Australia or is it best to order on-line from the US ....
Posted 30 March 2012 - 02:18 PM
Google wavetrain acoustics, they're the local agent
Not sure re online from us
Posted 31 March 2012 - 08:38 AM
Thank you .. will follow-up with home theatre progress as it evolves
Posted 31 March 2012 - 09:10 AM
Dino I actually have one if you wish to purchase it. It's of little use to me given the SSP I use.
Contact via PM.
Blade
Contact via PM.
Blade
Posted 02 April 2012 - 08:56 AM
The Audyssey Pro Kit I had available has now been SOLD.
Blade
Blade
Posted 02 April 2012 - 10:06 AM
Cheers Blade, thanks for that .......
How do you find the D2V, with the ARC system ? (vs Audyssey )
Posted 02 April 2012 - 12:54 PM
From my experience of ARC vs Audyssey, ARC is superior. I'll leave it there as that is just my opinion based on first-hand experience. The built-in Audyssey on most of the newer Processor/Receivers is now a higher resolution than what I used (16-Bit vs 32-Bit) so that may very well have changed.
regards
Blade
Posted 03 April 2012 - 03:47 PM
Thanks once again BladeRnR,
Will give the existing Audyssey a go first (Marantz AV7005) with AES-1 and hear the results ............
If I'm still not happy will look seriously into Audyssey Pro - then if still not satisfied would change preamp ............ a long way around, I know but I have an ugly room (for sound that is) !
Besides, this is fun
Posted 19 April 2012 - 03:57 PM
Just received the Audyssey Pro kit from Wavetrain and what a pleasure to deal with someone as professional as David ...........
