Channel 7 Doesn't Work
5 replies to this topic
#1 flatlinerz
flatlinerz
  • 33 posts
Posted 27 March 2012 - 08:02 PM
hey guys
on my Pioneer Kuro as of recent none of the channel 7's work anymore....use to work fine now doesn't at all, I checked signal strength its was like 40%....I have another plasma in the house and all the ch 7's work fine....any easy way I can fix this?
thanks
Edited by flatlinerz, 27 March 2012 - 08:02 PM.
#2 mtv
Posted 27 March 2012 - 10:21 PM
A firmware update on the TV is usually the fix.
#3 miata
miata
  • 1,560 posts
Posted 28 March 2012 - 09:46 PM
Silly question but when was the last time you unplugged and cleaned your aerial leads to that particular set? Or maybe even swapped leads from one of your other TVs, it could be something as simple as dirt/corrosion, reducing your signal strength.
#4 flatlinerz
flatlinerz
  • 33 posts
Posted 27 May 2012 - 09:10 PM
I have unplugged and put it back in still does nothing....it was working for a little while now its back to no signal....the lead only 2 years old got it from jaycar...you think that might be the problem?
thanks
#5 mtv
Posted 27 May 2012 - 09:47 PM
Have you installed the latest firmware for your TV as I suggested 2 months ago?
#6 flatlinerz
flatlinerz
  • 33 posts
Posted 21 June 2012 - 03:36 PM
I am not to sure how I install latest firmware to my pioneer?
