Please Don't Turn Off The Analogue Tv Signals
Posted 22 March 2012 - 11:15 AM
Posted 22 March 2012 - 12:36 PM
FWIW when the analogue network is completely shut down, the digital transmitters will be powered up quite a lot so everyone's reception should improve a lot then. But until then it sounds like you need to have your antenna checked by a professional.
Peter
Posted 22 March 2012 - 01:11 PM
Under certain specific conditions, yes. Ordinarily, no.
There may be certain specific instances of this (where there are adjacent channel/co-channel interfernce issues), but generally speaking, the power level should remain unchanged*.
(*I have no idea if this will be the case after band restack occurs.)
(Edit: Can't help feeling the first post is a troll post.)
Edited by M'bozo, 22 March 2012 - 01:12 PM.
Posted 22 March 2012 - 04:19 PM
Multivits, on 22 March 2012 - 11:15 AM, said:
best : (
As a matter of interest, where are you located ? As has been already suggested you may have some antenna grief now that is
affecting your tv signals both digital and anologue.This can only be checked by someone with a digital signal meter.
If you are going to loose reliable tv reception when the analogue gets turned off there is the VAST satellite system for people in
your position , which is now in SD and HD widescreen with program guides etc, which is far better than analogue in picture.
The key to it all is where you are and do you have a faulty system now that is not delivering the required signal quality to
maintain tv in the bad weather.
Cheers Tazzy.
Posted 22 March 2012 - 05:49 PM
If your digital reception has issues in poor weather, then in all likelyhood it hasnt been set up correctly*, a good digital system will have no problems whatsoever with almost any amount of rain or even snow. Actually a reasonably good chance, is that the birds have been at your external cabling and waters getting in.
* Note: (Or you are right on the very outer outer limit of the particular transmitter you are currently aiming at)
As Tassy has said, if your system is setup properly and you are still having these issues, than you can get satellite free-to-view digital tv.
Posted 22 March 2012 - 07:12 PM
This will answer most of your questions http://www.digitalready.gov.au/
Also go to http://www.dtvforum....hp?showforum=82
Select your area and then read "Get the best reception" There may be a repeater near you on other channels. In newly measured black spots some new repeaters are being installed.
Edited by alanh, 22 March 2012 - 07:14 PM.
Posted 27 March 2012 - 09:54 AM
Posted 27 March 2012 - 07:01 PM
You could have said this about cable TV which has been around a long time particularly in the USA. It has not taken off here because free to air is cheaper than paying telecom companies. The same will still apply to the NBN.
The NBN has been testing using HD video for Doctors appointments from remote locations (now there is a Medicare item number), legal consultations etc. There is plenty of other applications than just entertainment for the NBN.
Also consider that S3-D HD 50 frame/s video requires around 30 Mbit/s and a dwelling's allocation is 100 Mbit/s. So if three people watch different programs the whole allocation is used at that time. What happens if this is on a large scale. What happens through the network to the playout centre!
Broadcast is a cheaper one way communications system particularly in areas of lower population densities.
Posted 28 March 2012 - 08:05 AM
Posted 28 March 2012 - 03:59 PM
if you have drop-outs in bad weather in your area you need to find a way of getting a better signal.
antenna orientation to the correct repeater
correct antenna
correct connections
ensuring you're receiving the RIGHT signal for your antenna (digi channels can be broadcast on either or both UHF and VHF in your area)
amplify the signal at your end
Posted 02 April 2012 - 11:09 AM
Thanks for the replies. The bird cable attack I will check but when I was up on the roof last the connection was fine and dry and we had problems back then (thats why I was up theer on the roof)
I have checked the antenna direction and it is aimed at Gore Hill Sydney.
Channel 9 (GO etc) is the worst we loose the signal daily. But not so much others. Although CH7 can go under extreme heavy rain.
But never ever loose SBS. Is ther any clues in here?
TIA
Multivits
Posted 02 April 2012 - 01:02 PM
it has a 200KW transmitter, compared to 50KW of the others
http://ozdigitaltv.c...rmon-Willoughby
you may be better off swinging around to the north east and re-scanning
http://ozdigitaltv.c...s/NSW/32-Bouddi
and teh maps show you teh frequency you should be looking at
NOTE:
if you have a VHF ONLY antenna then any stations over 300MHz will be received properly
and likewise with a UHF only, stations under 300MHz will not be received properly
looking at teh site you're pointing at SBS is at 570MHz (UHF) and all others in the VHF band
so you may only have a UHF antenna
the other site has UHF only signals which may fix your issue
Posted 02 April 2012 - 01:04 PM
alanh, on 27 March 2012 - 07:01 PM, said:
Layer 2 IP multicast.
NBN's media release, multicast technical discussion paper, and invitation for Expressions of Interest.
Posted 02 April 2012 - 04:58 PM
Posted 02 April 2012 - 05:18 PM
It depends on where in Berowra you are. There are some deep valleys in your area.
Can you receive ABC1 on analog (channel 2)?
I suggest you read http://www.dtvforum....showtopic=11367
From 2014 SBS will move to channel 7 and the 7 Digital will remain on channel 6.
So for this all that is required is one of the antennas in the H3 link in the above link. If you have terrain between you and Artarmon, when viewed from your roof, then the blocked path recommendations apply.
The reason why Nine, Gem, Go! and 9Extra are unreliable is that their transmitter tower if further south than the Mowbray Rd Artarmon one for 7 and Ten networks and the Broadcast Australia tower in Pacific Highway for ABC.
If you want SBS/TVN in the meantime I would add a high gain H4 antenna in the H4 link above.
Posted 02 April 2012 - 07:10 PM
TIA
Multivits
Have you typed in your address on the 'Myswitch' web sight to see what it says about signals at your place, and /or clicked
on alternate transmitter locations ? If you are high up you may be able to get signals from the Wollongong Knights Hill towers
on UHF.You would need a signal meter to ascertain if the signals are adequate.
Tazzy
Posted 02 April 2012 - 10:46 PM
My suggestion is not to place value on AlanH's advice, he is commonly in error and surprise surprise he is again, his statement above is wrong.
James
#19
Posted 04 April 2012 - 02:29 PM
Propagation of RF signals due to rain will not depend on whether it is an analogue or digital transmission because all transmitters operate in the analogue domain irrespective if they are modulated by an analogue signal or a digital signal. Rain cannot differentiate between an analogue TV signal or a digital TV signal but it can have different effects for different frequencies. The same applies to TV antennas, they cannot differentiate between "digital" and "analogue", but they are very frequency conscious.
Posted 04 April 2012 - 03:13 PM
by "frequency conscious" do you mean multipathing?
This is the top answer for me. : )
I think all things considered I will get a new antennea with some good gain (20db enough?) when I win the lotto!
#21
Posted 04 April 2012 - 03:22 PM
I was referring more to the resonant nature of antennas and that they are designed and manufacture to work at different frequencies. Some of course are designed to be broadband antennas by having a 'combination" antenna such as a VHF/UHFyagi.
Most antennas I am aware typically have a gain of anywhere from 10 dB to 15 dB. Getting a high gain broadband antenna is a challenge.
Of course Multi-pathing too is frequency conscious (or wavelength dependent)
#22
Posted 04 April 2012 - 06:46 PM
Multivits, on 04 April 2012 - 03:13 PM, said:
Theres a good chance its not required anyway, check what your neighbours have, in most circumstances, what they have will do the job equally well at your place.
Spending money on equipment to DIY aerials can quickly turn into a money sink. Get an installer, find out whats wrong. It could end up being cheaper than replacing an aerial anyway.
#23
Posted 19 June 2012 - 08:33 PM
If the antenna has a faulty balun this could be the cause (or one of many) of your problems
Edited by andrewlace, 19 June 2012 - 08:36 PM.
