Ipod Dock
7 replies to this topic
#1 Jutta
Jutta
  • 2,334 posts
Posted 07 March 2012 - 11:41 PM
I want to add an iPod dock to my system for the missus and kids.
Still have a Yam 1800 hooked up to Emotiva preamp and power amp.
Someone suggested a Denon something something a while back, just want to see what the options are today. Could pick up a cheap Yam Docking Station but wanted something a little better sounding, if possible.
I add most of my songs from CD in highest quality possible , buy very little direct from iTunes.
Anyway, anything suggested I'll take on board, thanks in advance.
Do I hook up direct to the Pre for best sound??? I assume that would be right?????
#2 Gutty
Gutty
  • 4,053 posts
Posted 09 March 2012 - 08:53 AM
Yes, direct to the pre for best sound for sure.
As for a dock, i'm not really up to speed on what's hot right now. From memory Al is pretty happy with his Cambridge dock....
#3 ajm
ajm
  • 10,308 posts
Posted 09 March 2012 - 09:09 AM
These get a pretty good rap: http://rio.com.au/pr.../911/pure-i-20/
Keep meaning to grab one but not got around to it yet.
#4 GaryCook
GaryCook
  • 472 posts
Posted 09 March 2012 - 09:53 AM
I use an Apple IPhone/IPad converter to HDMI and plug it straight into the processor, I figure the DAC in the processor is going to be better than one in a cheapy IPod dock. Gives HD video as well.
Gary
Posted Image
#5 :)
  • 30,786 posts
Posted 09 March 2012 - 10:31 AM
yes I've got a couple, the cambridge id50 and the arcam rdock that I use in my lounge room and bedroom systems. can highly recommend either if hooking up over analog and for 2ch. these utilise the inbuilt wolfson dacs of the ipads/iphones which are actually pretty good but by passes their crappy headphone output and fixes up the levels of the analog output if hooking upto 2ch gear for a good result.
can also use a digital dock, but theyre quite expensive and then have to use a separate dac to go from digital to analog or go into an avr or processor.
if hooking over into av processor or avr the hookup cable gary has posted above is going to be pretty hard to beat. another option if want to do it wirelessly the appletv at $100 or so is also a good addition that can stream off any i device to your tv or anything else :)
#6 swordfish805
swordfish805
  • 4,256 posts
Posted 09 March 2012 - 02:09 PM
If you have an AppleTV you don't actually need to iPod (the Apple TV will just play content itself) - but if you have golden ears, you'd probably want to bypass the appleTV and use the DAC in your amp.
#7 Robbks
Robbks
  • 209 posts
Posted 09 March 2012 - 03:20 PM
EDITED.
already answered
Edited by Robbks, 09 March 2012 - 03:26 PM.
#8 Jutta
Jutta
  • 2,334 posts
Posted 12 March 2012 - 07:02 PM
Cheers all. Will check out a couple of the suggestions. The Cambridge perhaps as it will be direct to the Pre
