Sony Kv-Hr36M31
Posted 05 March 2012 - 02:33 PM
Posted 06 March 2012 - 07:40 AM
But seriously, it's indeed sad to see superior technology being abandoned.
I dread the day I'll be parting with my KV-HR.... Mine broke down last year after 7+ years but I fixed it and hope to get another 7 years out of it!
Good luck with the adoption process....
Posted 09 March 2012 - 02:07 PM
It's sitting in my son's bedroom, can't bare to part with it.
Posted 09 March 2012 - 06:13 PM
Posted 11 March 2012 - 03:43 PM
Posted 12 March 2012 - 10:15 PM
Edited by EIEIO, 12 March 2012 - 10:18 PM.
Posted 13 March 2012 - 08:36 AM
http://www.hdtvsuppl...amato5rcar.html
unfortunately all the cheapies on eBay have a different type of connector (BNC). Never heard of it...
http://www.ebay.com....=item27c34bcf64
Edit: does anyone know where i could get a VGA -> RGBHV cable? seems pretty hard to find in Australia!
or perhaps i should just get a BNC cable as eBay has cheap BNC -> RCA adapters
http://www.ebay.com....=item414defa495
Edited by Dwain, 13 March 2012 - 09:30 AM.
Posted 13 March 2012 - 03:37 PM
Posted 14 March 2012 - 10:01 PM
Dwain, on 13 March 2012 - 08:36 AM, said:
At the time I couldn't find one with RCA connectors so I made my own. Just used an old monitor cable and wired the corresponding pins up to RCA plugs.
A quick Google search found a Australian company that sells them. - link
Edited by Dreamcazman, 14 March 2012 - 10:06 PM.
Posted 14 March 2012 - 11:18 PM
The vga to RGBHV cables that I have are a 2 metre quest cable and a hdfury cable.
HDFury supply VGA to RGBHV cables come with BNC ends. VGA end in female or male. Length is only 100mm but you can use a standard vga cable + gender changer to extend.
You can Buy two HDFURY cables for US$59 delivered.
http://www.hdfury.com/buy-hdfury-now/
HDFury2 has a RGB female plug and the HDFury3 has a RGB male plug. Also you will need 5 BNC to RCA connectors available from Hong Kong for abour $6 delivered.
Another great product HDFury sell is their GammaX adjuster. It gets the black levels just right. They no longer sell it by itself. You can buy it at curpalme
http://www.curtpalme.com/GammaX.shtm
If you buy both you will need the opposite VGA to RGBHV cable to match up. If you make a mistake gender changers are available at Jaycar for $7
Edited by EIEIO, 14 March 2012 - 11:21 PM.
Posted 15 March 2012 - 05:53 AM
Ill probably go for that one from GoCables. Unless someone wants to sell me a 2nd handy cable?
Posted 15 March 2012 - 02:43 PM
I have a VGA cable with RCA connectors on one end that I made from an old CRT monitor cable and break out cables for Component out from Nvidia cards from a few years back, they are available for free if anyone wants them.
Edited by Owen, 15 March 2012 - 02:56 PM.
Posted 15 March 2012 - 04:05 PM
yeah, some of the older cards can (i.e. HD2400 Pro). but i have a HP workstation PC i was planning to hookup and thought using the TV's functionality would be easier than finding an old card that fits my PC.
i also have a VGA -> 3 RCA (component) cable, but no use without the appropriate video card. does yours have the 5 RCA's for use as RGBHV?
thanks for the advice re: settings ...
Posted 16 March 2012 - 09:00 AM
Any VGA cable has wires for RGBHV so yours should be usable.
The next problem will be getting a TV compatible resolution and timing from the video card, 1280x720 at 50Hz should be relatively easy.
The defualt 60Hz used by PC's will give you a picture but will give you juddery motion with 50Hz Oz TV and PAL DVD's.
Edited by Owen, 16 March 2012 - 09:00 AM.
Posted 16 March 2012 - 02:15 PM
Posted 18 March 2012 - 02:04 PM
I ran mine as a HTPC for a whilst (with good results but could be a hassle) but now run it with the HD Fury. Plain sailing
Posted 19 March 2012 - 09:07 AM
Dwain, on 16 March 2012 - 02:15 PM, said:
I wouldn't bother trying to use 50Hz, the flicker would be too annoying, stick with 60Hz when possible. I remember the overscan on this TV was really bad, especially when using RGBHV. Component wasn't too bad, that might be the way to go, but I'd say VGA is your only option.
Widescream, on 18 March 2012 - 02:04 PM, said:
AFAIK, the US model had a DVI connector.
