Richmond Area, What Antenna Band To Use?
Posted 02 March 2012 - 04:16 PM
can someone please advise what band aerial should be used in the richmond area for como?
thx guys.
Posted 02 March 2012 - 04:40 PM
Edited by nbound, 02 March 2012 - 04:41 PM.
Posted 03 March 2012 - 05:05 AM
When putting up a new antenna in Richmond whenever possible I prefer to go back to MT Dandenong as this is usually less problematic. Not always practical but will likely be less of a problem longer term, (ie not having to change antennas/polarisation etc again)
Posted 03 March 2012 - 10:06 AM
nbound, on 02 March 2012 - 04:40 PM, said:
It's the Melborne suburb of Richmond.... Como is the name of the building in South Yarra which hosts the UHF translators.
Yes, band 5 UHF vertical antenna for Como.... although the wideband UHF phased array works well for Como, I agree the better option is the main TX from Mount Dandenong, if possible.
Posted 11 March 2012 - 07:56 PM
Posted 11 March 2012 - 07:57 PM
Posted 14 March 2012 - 06:49 PM
Posted 14 March 2012 - 10:05 PM
beeblebrox, on 14 March 2012 - 06:49 PM, said:
Indeed..... lots of us hanging out for Rialto.
Posted 19 March 2012 - 07:46 PM
Posted 11 May 2012 - 01:33 PM
Been noticing that the proportion of new installs inner city using LPs going up over the years. Certainly true in North Melbourne where I live. Not sure which installers working in NM are using them, but backyard neighbour recently had one installed (and on a mast half the height of what was there previously). I see plenty of them going in along Beach Rd where I ride, and more generally inner city.
Been more than happy with mine (Fracarro LP34) the last 5-6 years or so since I installed it*. Likewise for other people nearby that I helped out (friends, neighbours).
* Originally on the advice of gclark8, who seems to have retired from here (not that I read dtv forums much now), but seems to pop up on some cycling forums
Edited by longshot, 11 May 2012 - 01:36 PM.
Posted 11 May 2012 - 02:22 PM
thx guys.
As other posts have indicated a Band 5 UHF installed for vertically polarisation will suffice for Como, I would also install a good VHF/UHF combination antenna (like a Hills brand) and try and get Mt Dandenong, more importantly don't forget to use a high quality quad shield cable like RG6. Depending on your actual street address in Melbourne you should get error free reception from both. I would be very surprised if you could not get Mt Dandenong
Posted 11 May 2012 - 09:31 PM
digital doctor spock, on 11 May 2012 - 02:22 PM, said:
Plenty of spots where one or the other is problematic. given the choice I prefer to go to Mt Dandenong but in richmond sometimes como is better.
Posted 05 June 2012 - 07:21 PM
