Berardo, on Jun 26 2011, 07:36 PM, said:
Sammy must be pushing this update as kept getting reminder note of available upgrade on screen via ethernet connection. Took plunge and I am happy. Bluray definitely better. Not tried 3 d games yet but 2d to 3d works well. Happy with my TV - wat to go Sammy :-)
Hi Berardo
So, can you confirm something for me. I too am getting the nag on screen every 24 hours so Samsung must really want us to upgrade. My issue is that the only things mentioned in the change log don't even have anything to do with Australia...as least for the overseas version of 3009 which is the only place you can find a change log. So my questions are:-
1 Did the upgrade reset you settings, or were all your picture and operational settings preserved? Did you have to reconfigure anything?
2 Did the upgrade in any way negatively affect the otherwise excellent picture quality in ANY way?
3 Did it REALLY improve anything to do with 3D as I have no issues whatsoever with 3005?
avss01
