Wall Mounting Guide 101
393 replies to this topic
#376 diesel
diesel
  • 13,722 posts
Posted 13 October 2011 - 07:39 AM
That's a good looking job. Like your entertainment unit too. Where did you get that and how much was it?
Can remote IR commands work through the glass front?
Edited by diesel, 13 October 2011 - 07:40 AM.
#377 magna_elite
magna_elite
  • 19 posts
Posted 13 October 2011 - 09:02 AM
Thanks.
The entertainment unit was from Super-A-Mart!  From memory it was around the $500 mark or thereabouts?!  No problems with remote IR commands thru the frosted glass front (which slides out of the way as well).  PS3 uses bluetooth which also works fine thru the glass.
#378 mark_s
mark_s
  • 183 posts
Posted 02 February 2013 - 08:48 AM
Hi guys
can anyone reccommend if it would be safe to wall mount a 64" Series 8 Samsung Plasma to a house with steel frames? I dont have anything behind the walls there and the studs are 600mm apart. I would like to wall mount it but also i want to make sure that later on if need be i want to upgrade to the 80-90" TV's once the tech is better and they come down in price.
Right now i have the Paradigm SA-35 v3 Speakers in Wall, but i purposley got the Paradigm Studio CC-590 Centre because i didnt want to put the centre in wall incase a larger TV would cover the center later on. This center is pretty massive and i rather put it ontop of my cabinet than inside my cabinet (getting a custom cabinet designed next week) so any suggestions would be good. Thanks!
#379 diesel
diesel
  • 13,722 posts
Posted 02 February 2013 - 09:03 AM
Should be ok mounting onto a steel frame.
Just get the right type of screws - make sure you talk to the support guys/gals at Bunnings or Hardware store to get the right ones.
#380 Storm AV
Storm AV
  • 702 posts
Posted 02 February 2013 - 09:18 PM
Self drilling hex head roofing/cladding screws think about 65mm are what I use.
Be careful not to overtighten them as they can only be tightened so much before risk of gyprock damage or tearing the thread through the stud-
Its a good idea to drill pilot holes.
#381 mwd
mwd
  • 2,098 posts
Posted 02 February 2013 - 09:55 PM
Hopefully the mounting frame will line up with your studs otherwise you will be in trouble. Screws into gyprock will not support the weight. You will need to drill pilot holes into the steel studs the only way you will get the screws in. Roofing screws are ideal they should be meaty enough to hold the weight and are designed to be self tapping.
#382 Chopsus
Chopsus
  • 10,287 posts
Posted 02 February 2013 - 10:26 PM
Not ideal, but Super Wall Mates will do up to 20 KG
http://www.specialis.../Wall-Mates.pdf
I've had my rear speakers (15 kg each) hanging off them for about 5 years now with no problems.
Edited by Chopsus, 02 February 2013 - 10:29 PM.
#383 Storm AV
Storm AV
  • 702 posts
Posted 03 February 2013 - 08:11 AM
100% with you mwd, Screws into gyprock will not support the weight-
if you like your tv dont use wallmates,
if you have children dont use wallmates,
if you have pets in the house dont use wallmates,
if you have any common sense dont use wallmates on heavy items you want to stay on your wall.
Llarge items cause damage when they fall if you are not certain you can do a job properly get a tradesman in to do it-they have the knowledge and experience to get it done right and the insurance to cover if anything goes wrong!
Mark when drilling your pilot holes have your drill on a low speed setting-high will just burn the drill bit tip and make it blunt.
Edited by Storm AV Pty Ltd, 03 February 2013 - 08:28 AM.
#384 Chopsus
Chopsus
  • 10,287 posts
Posted 03 February 2013 - 10:03 AM
Oh well ... a day can't go by without mugman storm grinding an axe and having a troll from months back LOL! :hyper: :hyper:
Funny! It was a professional installer that put me onto them ... if you dig into the performance testing of them the large ones will do nearly double their rated weight (36 kgs for memory)*.
Its highly unlike that there will be two studs in the perfect position for mounting, at least one into the steal frame and these will support the others fine.
edit:* that's a vertical load - I would not use them for anything that hangs out from the wall applying any horizontal force (like a large shelf or hinged TV braket) ... and I DID say "not ideal".
Edited by Chopsus, 03 February 2013 - 10:45 AM.
#385 I'm Free
I'm Free
  • 81 posts
Posted 03 February 2013 - 11:34 AM
You can use extra large toggle bolts through the metal studs, this is essentially like using nuts and bolts.  Two on each stud will work perfectly.
#386 Storm AV
Storm AV
  • 702 posts
Posted 03 February 2013 - 12:00 PM
Nice I'm free, they are a safe option..
Mark, do it the right way and if later upgrade to a larger tv occurs you will have no trouble using the same mount.
Chops-best to stop suggesting things that will eventually cause damage to the user or their gear.
If you knew what you were on about you would know a 64in tv has a width of around 1300mm, the bracket is around 800mm, studs are at 600mm.
You have plenty of room to adjust horizontal position of the tv by either mounting the bracket up to 200mm either side of the 2 studs you secure to, you also have further adjustment by simply sliding the tv horizontally on the bracket.
Regardless of what brackjet you use the weight of the tv is at the front where the screen is, this will pull gyprock screws out!
No axes grinding just pointing out theres a right and wrong way to do things.
You remind me of alanh!
#387 Chopsus
Chopsus
  • 10,287 posts
Posted 03 February 2013 - 05:51 PM
Jason, are you saying that toggle bolts are better than Super Wall Mates? (note I was referring to Super Wall Mates and not the vanilla wall mates you have referred to) I have put the steel ones into pre drilled steel frame studs and they are rock solid.
Edited by Chopsus, 03 February 2013 - 06:27 PM.
#388 mwd
mwd
  • 2,098 posts
Posted 03 February 2013 - 07:02 PM
Super Wall Mates should be fine in steel studs just have to drill a bigger hole to allow for the diameter.
We probably misinterpreted your original post to be Super Wall Mates just through the Gyprock. I think the OP should be an expert at wall hanging by now. If using the Wall Mates I would probably go for 6 depending on the mounting frame to spread the loading.
PS I used a magnet to discover where the steel studs were behind the wall.
Edited by mwd, 03 February 2013 - 07:12 PM.
#389 Chopsus
Chopsus
  • 10,287 posts
Posted 03 February 2013 - 07:33 PM
I have a stud finder from Aldi that does steel, wood and power (to be safe) ... Iirc it was around$10
#390 Storm AV
Storm AV
  • 702 posts
Posted 04 February 2013 - 12:25 PM
Chops, thats where we differ, I dont use wallmates at all. Your super wallmates are the same as a toggle bolt-I would be suprised if they went deep enough to get the toggle behind the steel frame but if they have worked for you then all that matters is you are happy with them.
I, being in business and doing this for a living don't cut corners or use the wrong tools for a job.
Toggle bolts run through the steel frame would hold ok but not as well as the right self drilling hex head roofing screws.
If I correct someone on here its not an insult its a correction that will save someone time and often money.
#391 mark_s
mark_s
  • 183 posts
Posted 28 February 2013 - 09:22 AM
Hey guys, just a big thank you to Jason from Storm AV who came out to my place and wall mounted my Samsung 64" Plasma.
Was a pleasure to deal with, great price, and lots of help! I wouldnt of attempted to wall mount it myself (i cant even lift the tv myself for starters) so i was happy to have a professional come out and install for me.
I have a house with a Steel Frame, and this posed no problems. Jason used proper bolts to mount the bracket for the TV.
Thanks again Jason - highly recommended to anyone who needs to get a TV wall mounted professionally!
Edited by mark_s, 28 February 2013 - 09:25 AM.
#392 Storm AV
Storm AV
  • 702 posts
Posted 28 February 2013 - 02:01 PM
Thanks Mark, I appreciate your feedback and am happy that you are satisfied with the work done.
#393 maximus intelligensious
Posted 16 April 2013 - 12:25 AM
Seems storms has shown you up again porky, how's that egg on your face feel!
#394 diesel
diesel
  • 13,722 posts
Posted 16 April 2013 - 10:24 AM
Lets stick to the topic instead of personal insults please.
