peteru
Alternative TAP environment.
2 posts in this topic
As I mentioned previously, I have an alternative TAP development environment download available for those who are interested.
This is really only of interest to TAP programmers. I think that most professional programmers will be right at home with my version, as opposed to the Windows specific batchfiles that Topfield provide.
Here's the content of the README file included in the archive:
$Revision: 1.4 $
$Date: 2004/07/23 15:31:21 $
Copyright © 2004 Peter Urbanec
OVERVIEW
This archive contains a distribution of the TAP development environment
based on rev1.0 of the tap_and_samples.zip file released by Topfield in
April 2004. The TAP development environment allows a programmer to create
applications that can be executed on a Topfield TF5000PVRt. See
http://www.i-topfield.com for more details.
MOTIVATION
This distribution is designed to be used on a number of host platforms,
including Linux, Windows, OSX, *BSD and others. Dependencies on Windows
are removed and replaced with more portable alternatives based on freely
available GNU software. Some of the changes and improvements:
* Replacement of DOS line terminators with Unix line terminators.
* Correct case of filenames for case sensitive file systems.
* Configuration based on the TAP environment located in /usr/local/tap
* Automated Makefile system for both C and C++ programs.
EXCLUSIONS
This distribution does not include the crosscompiler environment required
to generate TAPs, since a different version will be required for each host
platform. Topfield make a Cygwin hosted GCC crosscompiler binary only
distribution available on their web site. Unfortunately, Topfield do not
make the source code to the crosscompiler available, nor do they publish
enough information to enable the creation of a Linux hosted crosscompiler.
If you can assist in the creation of a Linux crosscompiler, please post a
message in the "DVD & Hard Disk Drive Recorders" section of DBA Forums at
http://www.dtvforum.info/
CONTENTS AND INSTALLATION
The distribution will expand to a directory containing three items:
* This README file.
* Directory named "tap".
The tap directory should be moved to /usr/local, so that you end up with
the directories /usr/local/tap/include and /usr/local/tap/lib
* Directory named "SampleTAP".
This directory can go anywhere you like. It provides a trivial sample
project that demonstrates the use of the Makefile mechanism to build
a TAP.
