Digital Tv Card/device Roundup
108 replies to this topic
#101 digitaladvisor
digitaladvisor
  • 4,015 posts
Posted 27 March 2009 - 12:35 PM
Antec HDTV DVB T14BR
http://www.artec.com...roducts/t14.htm
USB 2.0 High Speed Interface
Free to Air Digital Terrestrial TV and Audio Program Playing
˙ Supports DVB-T Protocol (ETS 300 744)
˙ USB2.0 High Speed Interface Designed for HDTV
˙ Digital Terrestrial TV and Radio Program Playingl
˙ Uses the High-performance DIBCOM chipsetsl
˙ With remote control supportl
˙ Compatible with Windows XP, XP Media Center Edition (MCE), Vista 32/64 bit
˙ Portable Device without any other extra powerl
Video format: MPEG-II Main Profile & Main Level
Audio format: MPEG-II Audio layer I & II
Available to transfer TS (Transfer Stream) to PS (Program Stream)
Bundled software
˙Real-Time Digital Video Recording
˙Schedule Recording
˙Still Picture Capturel
˙Channel Auto scan at 6/7/8 MHzl
˙EPG (Electronic Program Guide)l
˙ Time-Shiftingl
˙ PIP (Picture in Picture)l
˙ MTS (SAP, secondary audio program)l
˙ Supports Teletextl
˙ Multi-Language Setup and Application Programl
Analogue inputs: No.
Software:
- Comes with Software
- Watch digital terrestrial TV and listen to digital radio on your PC
- (Hybrid only) Watch analouge TV and listen to FM radio
- Fully Resizable TV in a window, or watch Full Screen
- Timeshifting support
- Record / Playback Live TV
- Scheduled recording
- Playback recordings
- View in widescreen (16:9) or normal (4:3)
- Now and next information
- Remote control support
System Requirements:
- Windows Operating System (2000/XP - NOT 98se or ME) (XP Recommended)
- Pentium III or AMD CPU running at 800MHz or higher (2.4GHz or higher processor recommended for HD viewing
- 64MB or more of RAM
- 20MB or more of free hard disk space **
- Graphics card (or onboard graphics) preferably AGP, capable of supporting 800x600 minimum resolution at 16-bit colour and hardware overlays or DxVA compatible video card
- Sound card (or onboard sound) and speaker combination.
- DirectX 7 or greater.
Third Party Applications: Any BDA compatible application.
BDA Drivers: Included
Other Comments:
Tested: Yes in QLD South East.
Easy to configure.
Works and tested with Media Portal, Webscheduler, DVBViewer
Considered Performance: 9/10
#102 The_Phantom
The_Phantom
Posted 21 April 2009 - 09:46 AM
Bundled software
˙Schedule Recording
˙ Time-Shiftingl
Software:
Other Comments:
Easy to configure.
I installed it on my Toshiba lappie, XP, yesterday, (connected to the external antenna on the roof) set my region to Australia, did the channel scan thing and it only found the 7 SBS channels, which were all excellent quality. Is it possible that I would need to set my region to something local, like Melbourne or VIctoria. (the drop down menu only lists countries as a region option). Is there something I am doing wrong?
#103 digitaladvisor
digitaladvisor
  • 4,015 posts
Posted 24 May 2009 - 10:42 AM
SBS is on UHF.
Australia has bands of VHF and UHF. 9/7/10/2 are VHF.
VHF could be a reception issue in your area. Aerial booster for VHF or high gain aerial to target VHF.
This device works on the margins very well - it aren't a "deaf" device for reception.
The channel search is thorough on this device.
The drop down menu is good to go for all of Australia by regions.
DA
#104 charlesc
charlesc
  • 2,613 posts
Posted 01 June 2009 - 05:12 PM
SPAM reported
#105 DrP
  • 16,740 posts
Posted 10 July 2009 - 07:33 AM
spam spam spam
reported
#106 renura
renura
  • 5,990 posts
Posted 13 January 2010 - 10:08 PM
DigitalNow DNTV Dual Hybrid (7164) PCIe
Product Website
www.digitalnow.com.au
Digital Tuners
PCI Express interface Low Profile form factor
Dual DVB-T Tuners
Supports all Australian DTV formats (including SDTV and HDTV)
Analogue Tuners/Inputs
Dual Analogue Tuners
Dual Analog Video Capture (S-Video In, Composite Video In, Component Video input) - hardware encoders
Support worldwide NTSC / PAL / SECAM Analog TV System
FM Radio support
Minimum System Requirements
Microsoft Windows XP SP2
P4 3.0GHz CPU or Above (for 2 tuners operation)
512M RAM or Above
VGA Card with 64MB Memory (DxVA support recommended)
Sound Card or On Board Sound Chip
One Free PCI Express Slot
Microsoft Direct X 9.0C or above
UHF/VHF Antenna for DVB-T and Analog Terrestrial TV
Software
Optional - DNTV Live!, developed in Australia and specifically designed for local Australian conditions. It supports Digital Terrestrial and Satellite TV, including PayTV services. Extensive list of features include multi cards support, fully resizable PIP, decoder selection, DVD playback, multiple recording format (DVR-ms, MPG, TS), etc. More details available here
- DNTV Scheduler Pro - a state of the art application for scheduling recordings of Digital TV and Digital Radio (Terrestrial and Satellite) broadcasts, using one or more DVB tuner devices. More information about DNTV Scheduler Pro is here
Nil
BDA Drivers
Yes 32bit and beta 64bit
Works with MCE 2005, Vista/Windows (32 and 64 bit versions) and other BDA based applications
Linux Support
Not Yet
Mac Support
No
Package Contents
PCI-e x1 Card
Remote Control Kit
A/V Cables
Power On/Off Cable
Mini DVB-T Aerial (for very strong signal areas only)
Installation CD (includes drivers and installation manual)
Low Profile Mounting Bracket
#107 bopperman
bopperman
Posted 10 February 2010 - 07:59 PM
Hi I am new to the whole forum thing so here goes I have an USB tuner and I decided not to use the standard tuner software,
so I opted to use a program called sage TV witch works great but Im trying to find a program that if I find a show in the EPG and set it to record it say in two days time, for the tuner software to boot it self up when required then record the show and close again dose such software exist??
#108 jalyst
jalyst
  • 185 posts
Posted 28 May 2010 - 12:24 AM
Can anyone recommend a decent PCI/e DVB-C card?
One that has verified support with Linux & ideally is available for purchase in Oz.
I have a few candidates, just curious to hear other peoples experiences.
I would prefer also that it was "dual"...
I've looked everywhere and I fear such a best does not exist.
Edited by jalyst, 28 May 2010 - 12:25 AM.
#109 alice.liu
alice.liu
  • Validating
Posted 07 August 2015 - 04:39 PM
TBS DVB-S2 Digtial TV Tuner
www.buydvb.net
Tuner/Demod:arious, depends on the device
Analogue inputs:NO
Software:CD/DVD drive for software installation
Windows XP / Vista/7/8/10, Linux
Pentium 4 2.0 GHz, Pentium M 1.3 GHz
For HDTV: 2.6 GHz multi core processor
Hard disk with min. 1 GB free capacity
Sound and graphics card with support for DirectX 9 or higher
Available PCI Express x1, x4, x8 or x16 slot
Third Party Applications:Support Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC, MythTV,VDRs
BDA Drivers:up to the latest kernel 3.X are ready.
Linux Support: Yes
Package Contents:
1 x TBS6908 Professional DVB-S2 Quad Tuner PCIe Card
1x Power cable
1 x Software CD
