Single Frequency Networks (SFN)
142 replies to this topic
#101 Andy Pham
Andy Pham
  • 5 posts
Posted 27 August 2010 - 06:28 PM
Who has experience about SFN in Australia, please tell me the distance between transmitter in reality?
In theory with mode 8K, guard interval: 1/8, 64QAM, the maximum distance's about 67km, but it uses for outdoor. Because attenuation of signal receive indoor, so the distance's smaller than in theory. Some one told me, in Berlin (Germany) they use 310m hight antenna but the distace between transmitter's only about 5km.
And please tell me how to solve black spot problem (Ex. Change power transmitter, use gap-filler)?
For example:
View here
As you see, there are 2 signals at TV but they're so weak and interfere other.
In reality, what do you solve that problem.
Many Thanks in Advance.
Waiting for your kind comments and information.
Edited by Andy Pham, 28 August 2010 - 05:20 PM.
#102 DrP
  • 16,741 posts
Posted 27 August 2010 - 06:54 PM
Why on earth are you asking these types of questions on a web forum?
I wonder if this rash of new low count posters is an impending sign of a spam outbreak.
Edited by DrP, 27 August 2010 - 06:56 PM.
#103 alanh
  • 13,035 posts
Posted 27 August 2010 - 06:58 PM
Andy,
NSW Transmitter list
Sydney Example
SBS Main transmitter Channel 34 200 kW Horizontal polarisation Omnidirectional
Kings Cross SBS 34 0.65 kW Horizontal polarisation least radiation to North
Manly/Mosman SBS 34 1 kW Horizontal polarisation least radiation to South
Between these transmitters is Sydney Harbour.
Bouddi SBS 34 1.25 kW Vertical polarisation Least radiation to East over the ocean. Possible interference, main transmitter and Manly/Mosman.
Gosford SBS 34 0.1 kW Horizontal polarisation Omnidirectional (terrain blocks the Bouddi signal)
Distances
Main to Kings Cross 7 km (Sydney Harbour bridge causes attenuation and reflected signals. Skyscrapers protect the southern coverage area from Kings Cross from the main signal)
Main to Manly/Mosman 13 km terrain shields the area from the main signal
Main to Bouddi 39 km some terrain shielding
Bouddi to Manly/Mosman 34 km no terrain shielding
Bouddi to Gosford 11 km some terain shielding
#104 Andy Pham
Andy Pham
  • 5 posts
Posted 27 August 2010 - 09:04 PM
Thank you so much, Alanh.
I'm searching more information.
Best regards
#105 lunar_man
lunar_man
  • 8 posts
Posted 31 August 2010 - 02:14 PM
Dear experts,
Please help me!!!.
In my project, we use SFN network to deploy the DVB-T.
Next time we have to test this SFN network, please tell what methods, deivces we can use and what parameters need to be tested ?.
Please note that we use transmitters from R&S manufacture with 3 types: 600w, 1.3kw and 2.7kw.
Looking forward to receive your informations.
thanks & best regards.
#106 alanh
  • 13,035 posts
Posted 31 August 2010 - 05:16 PM
Lunar_man
If you are in Australia you need to contact the Australian Communications and Media Authority for licencing etc.
If you are outside Australia you need to say where.
#107 lunar_man
lunar_man
  • 8 posts
Posted 01 September 2010 - 12:24 PM
Thanks AlanH,
Of cource, we had license for this project and i am from Viet Nam.
In my question, i want to know about technical information. Could you tell me about that ?.
Thanks & Best regard
#108 Andy Pham
Andy Pham
  • 5 posts
Posted 01 September 2010 - 08:55 PM
In theory with mode 8K, guard interval: 1/4, 64QAM, the maximum distance's about 67km, but it uses for outdoor. Because attenuation of signal receive indoor, so the distance's smaller than in theory. Some one told me, in Berlin (Germany) they use 310m hight antenna but the distace between transmitter's only about 5km.
For example:
View here
Hix, Anyone has experience about SFN interference ?
Look at the picture again and look at next picture, there are some signals which are out of guard interval (words bold).
View here
Please be kind tell me how to deal with the above problem ?
Thanks.
Edited by Andy Pham, 01 September 2010 - 09:04 PM.
#109 alanh
  • 13,035 posts
Posted 01 September 2010 - 11:54 PM
Andy & Lunar_man
Set the period at the bottom of the Central Coast Forum to all dates and then you can see the reports of SFN interference. There are also some antenna installers contributing to that forum.
The ABHN37 transmitter, Newcastle is 250 kW Erp horizontally polarised, omnidirectional and Wyong on the same channel but is vertically polarised and has an radiated power of 1.25 kW. This combination gives some problems
The SBS 38 transmitter, Newcastle is 500 kW Erp horizontally polarised, directional antenna, away from Wyong on the same channel but is vertically polarised and has a radiated power of 1.25 kW. This combination gives less problems.
Mt Sugarloaf (Newcastle) to Forresters (Wyong) 58 km straight line.
I do not live anywhere near this area. Antenna istallers with digital field strength meter can measure the guard interval (Which is the Adaptive equaliser mode which is used to determine the delay and strength of reflected signals or SFN settings.
#110 jetskier
jetskier
  • 47 posts
Posted 02 September 2010 - 06:35 AM
I would have to assume you have read the book by Walter Fischer ISBN 3-540-01155-2 ? It is invaluable if you maintain SFNs, and even more invaluable is attending Walters seminars.
#111 jetskier
jetskier
  • 47 posts
Posted 02 September 2010 - 07:46 AM
View here
Thanks.
The picture you posted is NOT a real world impulse response, it has been set up in a laboratory, likely with a rohde & schwarz SFU. So the question you are asking about dealing with SFN interference makes no sense. So you must have access to a test laboratory, so it is easy for you to figure out this problem for yourself. This board is for real world reception in consumer land, but I'm happy to answer any relevant meaningful questions (even though many contributors believe I don't know $h!t from clay).
#112 alanh
  • 13,035 posts
Posted 03 September 2010 - 08:49 PM
Lunar and Andy
Modulation: 64 QAM
Code Rate: 2/3
Min Carrier to noise ratio 20 dB
Guard interval 1/8
8 k carriers
#113 lunar_man
lunar_man
  • 8 posts
Posted 25 January 2011 - 08:25 PM
Dear Alanh,
Could you tell me what is problem in SFN ?
We have 2 transmitter stations: Tx1 and Tx2. And we want to test signal some places between Tx1 and Tx2.
In these places, we follow test case below:
- Tx1 OFF, Tx2 On: result signal is good
- Tx1 ON, Tx2 OFF: result signal is good
- Tx1 ON, Tx2 ON: result signal is not good ( MER decrease, so our equipment can not decode). And how can we solve this problem ?
thanks & regards
#114 Rusty Juggler
Rusty Juggler
  • 242 posts
Posted 25 January 2011 - 09:24 PM
Dear Alanh,
thanks & regards
Sounds like you don't have an SFN but rather two interferring transmitters!
Are the modulators locked to GPS (10MHz & 1PPS) and running in SFN mode?
Is the Transport Stream SFN capable (GPS locked with a valid MIP inserted)?
Without either of these criteria met your SFN won't work.
Rusty
#115 alanh
  • 13,035 posts
Posted 26 January 2011 - 01:04 AM
Lunar_andy,
I agree with Rusty,
Also;
Does one transmitter have its antenna horizontally polarised and the receiver using that transmitter using a high gain horizontally polarised Yagi-Uda antenna.
Is the other transmitter's antenna vertically polarised and when the reciever is receiving that transmitter using a phased array antenna mounted so that its dipoles are vertical.
Additionally is the signal delay feeding the transmitters adjusted to make the signal arrive at halfway between the transmitters simultaneously. The relative delay may be adjusted to make the "centre point" over a less densely populated area.
Not only does the modulator and the upconversion oscillators have to be the same frequency in both transmitters, the source program must be identical except for the delays mentioned above.
#116 Rusty Juggler
Rusty Juggler
  • 242 posts
Posted 26 January 2011 - 10:25 AM
This is not a requirement for SFN operation, both TX's can be horizontally or vertically polarized, the STB front end deals with this as if the secondary signal is an echo of the primary.
True, but what are the chances -in this particular case- that the RX is exactly in the middle.
Yes the oscillators have to be phase-locked to a common source, usually GPS derived 10MHz, but more importantly the modulators have to dispatch bit-identical data streams on every carrier. This is achieved by synchronising the Mega-frames between modulators. The Transport Stream has to contain MIP's to identify the Mega frame boundaries in relation to the 1 Pulse Per Second (GPS derived-) time base. If the MIP's are missing the modulators cannot be synchronised and the SFN will fail. SFN modulators that loose the MIP or the reference signal will usually mute their output so the TX will shut down.
Rusty
#117 alanh
  • 13,035 posts
Posted 26 January 2011 - 03:18 PM
Rusty,
All ACMA allocations use alternate polarisations moving in a particular direction. For example Bouddi and Wyong are vertically polarised and Gosford which is in between is norizontally polarised along with the high powered Newcastle transmitters.
The reason for this is to make the area where similar strength but delayed signals as small as possible.
#118 Rusty Juggler
Rusty Juggler
  • 242 posts
Posted 26 January 2011 - 03:42 PM
Alan,
Some, or even most, but definitely not all. For instance SBS 34 from Artarmon, Kings Cross and North Head are all Horizontal and I'm sure there are other examples. From a network planning point of view it may well make sense to use H/V alterations, from a pure technical point of view it is not a requirement for every SFN.
Rusty
#119 CWulf
CWulf
  • 195 posts
Posted 26 January 2011 - 04:20 PM
Rusty,
What rot - the polarisation is the same as the analog polarisation and that was determined by completely different planning processes. There is absolutely no ACMA planning process which deliberately alternates polarisation of digital services at existing analog sites.
BTW, the enquiry is from a fellow in Vietnam experimenting with SFN operation. If he wants any useful advice he should talk to equipment manufacturers, talk to broadcasters or service providers like Broadcast Australia or read the appropriate engineering manuals. Posting to forums like this and respecting Alan's waffle is hardly a professional or even academic approach!
Edited by CWulf, 26 January 2011 - 04:31 PM.
#120 jrp001
jrp001
  • 169 posts
Posted 26 January 2011 - 06:29 PM
I agree with the SFN stuff
They have got R&S transmitters
Im sure R&S would give them tech support on set-up
#121 lunar_man
lunar_man
  • 8 posts
Posted 27 January 2011 - 03:03 PM
Thanks all of you!
I can sure about our SFN network is satisfied all condition of SFN, include GPS, same TS with MIP, same frequency, TX with SFN mode.
And we using Horizontal polarised for all TX stations. About manufactures, they only provide equipment and it is difficult to ask them about problems like this.
Additionaly, the distance between Tx1 & Tx2 station about 15 km. So, i don't think it is effected by delay.
Sory for inconvenience, i have not really understood our problem. In your country, this problem does not happen ?
Thanks & regard
#122 Rusty Juggler
Rusty Juggler
  • 242 posts
Posted 27 January 2011 - 04:27 PM
Thanks all of you!
Thanks & regard
Hi Lunar_man,
What sort of link is used to get the Transport Stream to the two transmitters? I assume that the stream is either ASI or IP based but regardless of that, the most important thing is to make sure that no rate adaptation takes place that destoys the timing constraint of the stream. Are they dedicated point-to-point (dark fibre) links or are they carried as a 'service' by a Telco?
I would expect the modulators to alarm if there were any discontinuities in the incoming stream.
Finally, what type of receiver do you test with, a domestic STB or a professional IRD?
Rusty
#123 lunar_man
lunar_man
  • 8 posts
Posted 28 January 2011 - 12:28 PM
Hi Lunar_man,
Rusty
Hi Rusty,
Our transmission line using fibre point-to-point with IP. Then, IP signal is converted to ASI by IRD before put into trasmitter.
If input signal is not good ( no input, no MIP, datarate, SFN delay...), the modulators will alarm. And we using Promax product to test signal.
thanks & regards
Lunar
#124 Rusty Juggler
Rusty Juggler
  • 242 posts
Posted 28 January 2011 - 02:03 PM
Hi Rusty,
thanks & regards
Lunar
Well, if we can trust the IRD's to recover the stream without shuffling packets (what brand are they?) then we should trust that the input to both tx's is correct.
As for the GPS timing, do you use an external GPS clock or has the R&S modulator a built in one? If they are external, are they the same make / model?
I have seen a case where two different GPS devices were used with different duty-cycles, one was 50%, the other's 1pps impulse was more a needle shape, say 10%. Depending on whether the R&S modulator uses the rising or falling edge of the impulse the outcome may be quite different.
I don't know the R&S product too well and I don't know whether you can select whether to use the rising or falling edge of the 1pps impuls, but it may be worth checking.
Rusty
#125 lunar_man
lunar_man
  • 8 posts
Posted 28 January 2011 - 08:41 PM
Rusty
Hi Rusty,
thanks for your information.
Sory for inconvenience, but maybe you are understanding wrong about our problem.
Please note the, our SFN network run good almost places.
ONLY!!! some places happen this problem as i said.
thanks & regards
