Fs: Used Projector Screen Material 140 Inch Scope
No replies to this topic
#1 bucket23
bucket23
  • 195 posts
Posted Today, 12:32 PM
G'day,
I bought my 140inch scope screen from OZtheatre a few years ago. I just recently bought some accoustically transparent material from Oztheatre again.
I have the old Majestic3D screen material left over. You may need to use it on a 130inch size so that it overhangs when you attached it. I think there was about an inch or two overhang from when it was attached originally.
https://www.projecto...w&product_id=35
$500 ONO. I'm in Brisbane. Pickup only.
NOTE THAT THIS IS ONLY THE SCREEN MATERIAL AND THE T-GROVE RUBBER TO IMPRESS THE MATERIAL INTO THE FRAME.
You need to have your own frame. You may be able to buy the frame from Oztehatre or just make your own.
edit to add that the material is currently rolled up on the same packaging that the new accoustically transparent screen material came in, ie on a roll and in the box protected.
Edited by bucket23, Today, 12:33 PM.
