Portable Dvb-T?
2 replies to this topic
#1 matturn
matturn
  • 507 posts
Posted 10 September 2014 - 10:56 PM
Unless you're directly under a transmitter or using a roof mounted antenna, is there a tuner dongle/card + antenna combo that will generally get sufficent signal?
#2 viewer
viewer
  • 841 posts
Posted 14 September 2014 - 07:02 PM
http://www.ebay.com....=item19d8b561dd
http://www.ebay.com....=item19ef1e9799
http://www.aliexpres...1978099220.html
#3 matturn
matturn
  • 507 posts
Posted 16 September 2014 - 09:50 PM
Thanks viewer. I will look into those models.
