2014 Marantz
97 replies to this topic
#76 Parsec
Parsec
  • 56 posts
Posted 29 December 2014 - 05:16 PM
..and whatever they tell us we will not want to hear :no:
hdcp 2.2 will kill off a lot of stuff we do, it's not backward compatible and will have keys for devices. Hollywood are going to love it
#77 hxmonaro
hxmonaro
  • 18 posts
Posted 30 December 2014 - 11:22 PM
I picked up my new AV7702 this afternoon.
So far it seems to be going alright, I had to use the XLR cable from my microphone so I haven't been able to run a REW sweep yet but the Audyssy settings sound ok.
The only thing I have noticed so far is I had to change my PVR audio from PCM to dolby as it would only give me stereo via PCM which I never had an issue with my Yamaha.
#78 petetherock
petetherock
  • PipPipPipPipPipPip
  • 3,320 posts
Posted 10 January 2015 - 04:06 PM
Waiting for the AV 8802 to show up... won't be long now..
http://www.marantz.c...aspx?newsid=133
#79 cwt
cwt
  • 5,824 posts
Posted 10 January 2015 - 06:06 PM
FTA audio is either mpeg2 stereo pcm or 2ch/5,1 bitstreamed dolby digital monaro . Your pvr may be downmixing to 2.0 or you may be applying a dsp mode with the yammie ..double check your settings .
I wouldnt worry ; very little chance the marantz cant process the lossy streams properly  :thumbsup:
#80 hxmonaro
hxmonaro
  • 18 posts
Posted 10 January 2015 - 06:50 PM
It is not a problem, it's working now with dolby, I have not plugged the yamaha back in to confirm but it was always used in straight passthrough mode and would give me either 2ch or 5.1 depending on what I was watching, although it is possible that it has been working like that since getting a new topfield recently and this was just the first time I noticed.
I got REW up and running again and it has confirmed my thoughts that Audyssey handles Sub EQ better.  My yamaha needed a fair amount of tweaking to get close to an acceptable range but could never get it this flat.
#81 petetherock
petetherock
  • 3,320 posts
Posted 28 February 2015 - 11:25 PM
It seems that the AV 8802 will cost about $S 4250  in Singapore ...
That's more than a grand higher than it's cousin, the 7200... wow...
Those HDAM modules certainly aren't cheap..
#82 d4g
d4g
  • 321 posts
Posted 01 March 2015 - 01:40 PM
I picked up my av7702 on Friday
#83 d4g
d4g
  • 321 posts
Posted 01 March 2015 - 01:43 PM
Sounds great. Still tweaking I only did a quick 8 point Audyssey. I still am going to try a proper 8 point when it's all quiet. I also have the Audyssey pro but I need to buy the license for that
But for now it's crystal clear and very immersive.
And I'm only using 5.1 no atmos.
I'm also using the center dialogue on -3
What do others use ????
Denis
#84 HTPC-Guru
HTPC-Guru
  • 1,340 posts
Posted 03 March 2015 - 08:33 AM
How do u rate it compared to the 8801?
#85 d4g
d4g
  • 321 posts
Posted 03 March 2015 - 02:24 PM
I could safely say it's on par with it
I know the treble is not as tamed down av8801 a little warmer
And that's with xt32 on the 7702 where on the 8801 is with xt32 aud pro.
#86 d4g
d4g
  • 321 posts
Posted 03 March 2015 - 02:25 PM
The 7702 should be better once I do a pro cal
#87 d4g
d4g
  • 321 posts
Bass is better in the 7702 where on the 8801 stock xt32 had to bump it up a bit
#88 petetherock
petetherock
  • 3,320 posts
Posted 03 March 2015 - 03:23 PM
That could simply be a calibration issue?
Even moving your microphone up a little can result in a change in volume, which is often interpreted as a difference in sound quality.
#89 d4g
d4g
  • 321 posts
Posted 03 March 2015 - 04:54 PM
Nah the av8801 and the 4520 both had sub vol lower. It has been discussed everywhere even choppy a who had the av8801 said the sun is lower and had to bump it up a few decimals the 7702 the level is higher. Than it was in the av8801.
I had both units and the 4520 and 8801 did the same to me
Even though I set the levels before Audyssey to 75db
That was a minor thing I just upped it a bit and was fine.
#90 petetherock
petetherock
  • 3,320 posts
Posted 22 March 2015 - 01:42 AM
A review of the AV 7702:
http://www.hometheat...sor-review.html
#91 MRCRIST
MRCRIST
  • 3,618 posts
Posted 23 March 2015 - 09:18 AM
Some guru out there will find a way around it.
nothing is infallible.
#92 cwt
cwt
  • 5,824 posts
Posted 23 March 2015 - 06:37 PM
Trouble is Chris its hardwired into all the next gen equipment chipsets including sources ; repeaters[avr's etc] and sinks [panels ; projectors]
If one segment of the chain cant use its edid with another its dead  :no: wonderful stuff eh   :nuke:
#93 HTPC-Guru
HTPC-Guru
  • 1,340 posts
Posted 24 March 2015 - 09:30 AM
Solution a htpc with 2.2 graphics card ;)
#94 MRCRIST
MRCRIST
  • 3,618 posts
Posted 24 March 2015 - 11:53 AM
Yikes. Looks like the demand for new  Ferrari's will be on the increase in Hollywood next year.
Solution is to stay with 1080  and sit further back :D
#95 cwt
cwt
  • 5,824 posts
Posted 24 March 2015 - 02:00 PM
Exactly ; I dont have room for a bigger screen  :ermm:
#96 ronfishes
ronfishes
Posted Today, 07:29 AM
Hi guys,
Just noticed this thread and since I received my 7009 on Wednesday arvo, I thought I'd chime in here. I havn't read through all the thread yet so hope i'm in the right place.
Just thought I'd mention that I switched it on this morning and it had a notification for firmware update, so that is what its doing atm - estimated time 52minutes. Said something about improving stability and something else I think.
After a day of playing with it i'm pretty happy so far. Just a quick question, I have run Audyssey, should I run it again after a certain amount of 'burn in?'
Anyway, thanks to the guys @TCC for their professionalism, and the courier they used who also went out of their way for me :)
#97 petetherock
petetherock
  • 3,320 posts
Posted Today, 09:17 AM
IMHO, yes I ran Audyssey again, and did that a few more times after I moved my gear around a bit... Cheers
#98 ronfishes
ronfishes
Posted Today, 10:34 AM
Ok thanks Pete, and will most certainly rerun it if or when more speakers are added.
Another quick question, my TV audio seems a little low, its connected via optical to the receiver. It appears volume is max on the tv output, had to bump up the db to +10 on the digital input on the receiver. Is this ok? Will check it out again tonight.
Nice room BTW!
